DC/DC-Wandler
Verkaufe wegen Fehlkauf nigelnagelneuen DC/DC-Wandler!
Gerade erst heute erhalten.
DC-DC-Wandler 10-60V in und 12 bis 80V out!
Max out: 10A
Mit Kühlblech und Sicherung.
Strom und Spannung mit Poti einstellbar.
Achtung: die Ausgangsspannung muss 2V > Eingangsspannung sein.
Also ideal zur Versorgung von 24V Geräten mit einer 12V Batterie oder zur Verwendung einer 12V Solaranlage bei 24V Bordspannung u.s.w.
Features :
Input voltage : 10V -60V
Input Current: Maximum input current of 15A
Output voltage : 12V -80V continuously adjustable
Output current: maximum output current of 10A ( adjustable )
Output power: the effective power P = input voltage V * 10A
Conversion efficiency: up to 95% ( input voltage, current; output voltage andcurrent impact of conversion efficiency )
Short circuit protection : Fuse
Applications:
1.DIY an output adjustable car power supply, only need to enter the access12V power supply output voltage can be (14V-80V) free continuous adjustment,but the output voltage can not be lower than the input voltage.
2 universal car laptop power supply. Input connected to 12V power supply, theoutput voltage can be adjusted to the notebook need work.
3.Boost charger with 12V power supply is higher than 12V battery charging, forexample, 24V battery and charging current can be adjusted.
4.For electronic equipment power supply, as long as the voltage regulator tothe required voltage and current does not exceed the rated current is normal.
5.System before the power supply when doing a project about 24V of power inputof 10V-18V, the system board and a great power, common DC-DC module power istoo small, then this module will be your most good choice, do not debugdirectly on the machine can easily achieve high-efficiency high-power boost
Preis: € 8,00 zzgl. Versandkosten!
Geändert von Ferdlnand (26.07.2017 um 19:12 Uhr)
- Neue Themen erstellen: Nein
- Themen beantworten: Nein
- Anhänge hochladen: Nein
- Beiträge bearbeiten: Nein
Foren-Regeln
